RazMan
I've got a solo seat on my 2023 Roctane and fancy getting a backrest.
Any ideas guys?
Any ideas guys?
just may want to keep an eye on the circular antenna under the seat. About 2 of the plastic anchors holding the antenna broke on mine. I zip tied the antenna until I put my original seat back on the bike then replaced the part holding the antennaI ended up doing some research and confirmed that the seats from the classic fit a Roctane. You just need to remove the center seat mount that comes stock, move the turn signal connectors up a bit and fits like a glove.
Thanks for posting these pics.I ended up doing some research and confirmed that the seats from the classic fit a Roctane. You just need to remove the center seat mount that comes stock, move the turn signal connectors up a bit and fits like a glove.
On this seat no as it's a one piece seat.Thanks for posting these pics.
BMW site says that seat isn't compatible with the Roctane. But clearly it is. I think I'm going to go with it.
Question though. Do you know if it's possible to run it without the passenger seat as a solo? And also if you happen to know, is it compatible with the BMW Luggage rack?
Thanks for the quick reply!On this seat no as it's a one piece seat.
If you find a solo rider seat (BMW does offer them) it will work with it.
As for the BMW luggage rack, do you have a photo of the exact one your thinking of? If it's a similar style like mine then yes as theres plenty of space between the seat and where it mounts
