McEnroe
Hello everyone, I wanted to open a dedicated thread on this topic of corrosion and give everyone the opportunity to find out about rust spots / corrosion spots in advance and to take the appropriate prevention.
So please share the vulnerable areas you found here - please try to share a photo - as well as possible remedies (other than going back to the dealership ;-) )
I discovered three rust spots near the rear brake. The holes for the side license plate holder are very vulnerable. After washing, when the motorcycle is on the side stand, there is water in the holes and corrosion occurs.
As a remedy, I cleaned the holes very laboriously, with a brass brush, rust remover, some rust converter for the remaining rust, which I could not get out. Then I cleaned the correct screws (M8X20-8.8-MK; part number 07129908415) - mine were already free of microencapsulation because they were used before - and then coated them with Loctite 243 medium-strength. I then screwed these hand-tight into the holes - this should permanently eliminate the problem. The holes are on both sides of the swing arm - three in total.
I have reached out to BMW in Germany directly - I will keep you updated on this.
Thank you, McEnroe
Thank you, McEnroe
