South Florida keeps showing up this week
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter DRACKO
Thanks Em. Wow, I'm a bit confused. I only turned it two and a half times. So, since I weigh 110kg without gear, should I turn it between 10 to 11 full rotations? Maybe that's why the suspension feels so stiff and I feel every little bump; it probably has no travel left and is just bottoming out as soon as I sit down (zero damping). Thanks for the info. I'm going to make the correction! 👍🏻
It’s still a relatively harsh rear shock, but yes you should be around 14 considering fuel weight and gear (helmet jacket boots)
Imagine how a poor R12 would feel😳
