Switch Block movement
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter OzR18
OzR18
Sydney
R18 FE
I've only had my R18FE for 3 weeks and I've notices movement of both switch blocks - more the left than the right.
To be clear - the switch assembly unit can be "rotated" a very small amount on the handle bars.
Is this normal? Has anyone else seen this?
TIA.
Does anyone know the type/size of the small screw that holds the left and right switchgear in place? My old eyes cannot see it given the awkward position. Best to you.
