moleculo
Some little issues with the Radio feature on the TC that drive me nuts:
I'll add to this list as I discover more.
- The radio does not remember the last source properly when you use the Favorites feature. For example, if the last channel used in Favorites was a SiriusXM channel, the next startup, it sets the Source to SiriusXM on that channel. Then you have to change the source back to "Favorites" the next time you power it on. It should just remember the last setting.
- Audio Equalizer randomly forgets the setting. Frequently after powering on, one or both of the Bass/Treble settings are set to 0 instead of where I put it. It doesn't matter if it's a saved memory or not.
