fleabag
Thanks @Star-Lord for the suggestion. It was stil a bitch getting this plug off even with this tool, but pretty much impossible without it, at least for me. And, zero oil came out as expected.
It pulls straight out, which was difficult even with the forceps. It's also awkward to access, which makes it all the more fun. I did put some lube on it. Otherwise it would have been equally as difficult to insert.is it threaded or just pull straight out? probably easier next time if its got a little oil on it when you put it back?
As observed it is on the maintenance list so hats off to whom follows that. It very rarely will catch condense. It is the moisture in the crankcase vapors which can condensate. That mainly occurs when riding short city rides at low revs and then mainly under colder conditions.Can I ask why you pulled it off?
The strawberry taste or the slightly hotter one with a bit of eucalyptus?I did put some lube on it.
From my man cave off to a Neanderthal cave this afternoon. SeriouslyHe’s here all week folks...
