Those with a TC or bagger with a top case
RyBread
Elite Member
Could someone measure these out for me? I marked them in Green. I need the distance between the two mounting holes (could you check both left and right side to see if they are the same? and width.
I'm trying to see if I could modify and quick disconnect bracket.
You have the other end of those holes on your bagger, its the metal braces the panniers mount to. To measure that, remove both panniers and measure the distance using the threaded female ends you didnt use for mounting the panniers.
She's at the shop getting her first service, was hoping someone had or could take some measurements. Figured I'd start a project before I get her back 🤷🏻‍♂️
If not I'll go that route.
