Trailering
Trailered my R18B for about 7 hours. Straps through the lowest part of the fork/fender on the front, and one on each side around the wheel/tire at the back. Probably easier on a classic as the bags make the rear tough to find a spot. In any case, didn't move an inch over what can only be considered "roads" through a lot of rural Texas/Arkansas.
Thanks. Most advice that I saw online said to place the straps as high as possible, but there is no high place on the back of an R18.
I have hauled mine in the truck and on an open trailer and on the R18 bagger, I used the lower fork mounts where the flashers are. Didn’t budget for a few thousand miles. I have the rear ratchet down as well but it’s really not needed. I just like having 4 straps instead of 2.
This, really just there in case something goes catastrophically wrong, there's something preventing the bike from wholesale running off.
Took her out for a short drive, but need to get different straps before taking her on the highway.
So I'm about to trailer my TC home 600 miles........Looking like front forks down low around where fenders mount?...Also in the rear there dont seem to be good tie-down spots so just wrap around the tire/wheel??
Craig
Running a strap over the steering head will do little to nothing to prevent the bike from leaning in either direction.
You need an individual strap on each side attached to a secure attachment point like the lower tree or the lower fork above the fender bosses.
Also use a quality wheel chock like a Condor.
For anyone else's reference, I loaded my R18 TC into the U-Haul 6x12 trailer today. had to take of the windscreen to make it fit vertically, but otherwise... *dad voice* - "she ain't going nowhere"
also got the ramp at Home Depot for $150.
Had a weight rating for 750... and the bike is 950.... but it held just fine. :)
Where did you attach the rear straps to the bike? I put my bike up on a table to work on trying, to figure out good attachment points 2 Fwd & 2 Aft
