Do you know what size is handle bar grip? It is 22mm (7/8) ? Im try to purchase grip puppies
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter firstime911
firstime911
K1600GA, R1200gsa LC, R ninet, Super tenere 1200, Honda monkey, Burgman 650 and R18
Do you know what size is handle bar grip? It is 22mm (7/8) ? Im try to purchase grip puppies I'm not sure about the size to purchase
22mm/ or 1 inches diameter
Thank you
When I bought the wind shield brackets I ordered the 25 mm . And they fit perfectly.
I just checked now though.
And I found also more than 25,6 mm at the strait zones ( the bent zones have deformations, moving from 24mm to 25.8).
This size is very strange, it's not metric nor one inch. :unsure:
These tubes are generally 22 /25/32 mmm
1' = 25,4 mm
These tube are generally 22 /25/32 mmm
1' = 2.54mm
I'm getting an inch on the nose
Can anyone please provide me the dimension length of this grip please. I want to cut the grip puppies to fit the grip.
Thank you
Thank you
4 3/4 inches from outside the cuff to the end of the grip
4 1/2 from the inside of the cuff to the end of the grip
4 5/16 from the inside of the cuff to the end of the actual area you'd be gripping.
Dude, your R18 is arriving this weekend. Wait until it arrives and cut the grip puppies when it does. They'll be perfect. 😀
Couldn't wait anymore.. hahaha Thank you
