estoma
I have not checked whether this subject has featured previously, so please accept my apologies if I am waffling away, regurgitating known complaints;
- Slip-on exhausts resembling those on the R18 Concept (of course)
- Two different intake manifold options. One like the R18 Concept, with throttle bodies at the rear but with a proper plenum. The other with shortened tracts and the throttle bodies alongside the engine with pod air-cleaners, obviously including retro throttle body covers
- A better-looking Oil Cooler Cover, and preferably not Tupperware
- Analogue (display but digital operation) oil temperature and oil pressure gauges that can be mounted wherever one wishes
- Aesthetically complementing Indicators. The OEM ones look like they came straight out of Star Wars
- 21" x 3.5" laced front wheel, sealed proper tubeless
- 21" front fender, steel or aluminium, same size and style as the OEM 19" front fender
- 16" x 6.0" laced rear wheel, sealed proper tubeless
- Hard bags with matching bagger rear fender
- Sidecase Set Chopper 33l Craftride K3 incl Mounting Set best deal (motea.com)
Custom bags and minor tweaks
The first modification I made to my R18 was to figure out a way to mount a pair of saddlebags (https://francocuoio.it/) I already owned. It seemed wasteful to invest in the BMW set-up with those just sitting in the garage. Straight-forward enough, huh? Just needed suitable mounts. Several emails...www.r18forums.com
- Two different display options. 1) Digital multifunction display with different (also proper retro) themes and improved functionality - same size and shape as OEM. 2) Same as option 1 but built into an elongated headlight
- Rear air suspension. Hello, Arnott®!
- Rear light options
- TMPS, similar to FOBO® but with senders fitted inside the rims
- FOBO (my-fobo.com) - this might well need to be it for the foreseeable future.
- Accu-Pressure Motorcycle Tire Pressure Safety Caps (32-40 psi) – Sierra BMW Motorcycle (shopbmwmotorcycle.com)
- Centre Stand
- Front and rear paddock stands
