twisted throttle
This is the last mod I performed by deleting the evap canister. I pulled the side cover off to gain access to the canister hoses. The canister slides up and off the base. The hose coming out of the valve goes into the bottom half of the air box this hose can be cut back and plugged or take it all the way back to the barb on the air box bottom and plugged it is very tight in there. The hose coming from the gas tank is in barb connected sections just behind the frame to the left of the cover is the last one. This is were I tied the 7/32" vacuum tubing approx 24" running it over and down to the old canister mount that I cut back to reuse through it to the hole just in the frame just in front of the rear wheel. you will need to use a smart moto PVE-052 plug $21 to go in place of the valve. no codes were thrown after this mod.
