- Joined
- Mar 30, 2023
- Messages
- 957
- Location
- Goolwa, Australia
- Bike
- R18 FE and RnineT Scrambler
Closest thing I've found.....
Australia doesn’t have the strict emission laws that Europe has.Happy that you are happy.
I do not know what the operating criteria for the flaps are.
They are a ´Bobby dodger´ for the EU noise emission tests for homologation.
This test involves idle, mid revs when stationary but also roll by test at various speeds incl. full throttle accelleration.
The CPU can tells the servos to actuate the flaps under ány of above and more conditions.
Although ´we´ assume when it actuates it can very well be that it only actuates with a lot of throttle between 50 and 70 km/h per example.
It is ONLY an invention to pass the EU noise test.
The tests also involve the stationary measurements to establish a sound level which can be verified during periodic inspections and at road side stops.
This dB level is included on the EU vehicle license registration documents and it is a bit higher than the value measured at homologation to compensate for potentially increased noises by use.
At inspection they will check a homologation number on the mufflers as well. If one decided to fit an after market one, the homologations document of the mufflers must be presented with the vehicle papers at inspection.
Anyway, I am unaware of when, under which circumstances, the flaps are actutated. Would lóve to know.
BMW makes no OZ market model so still same as OEM bike exhaust flaps comeAustralia doesn’t have the strict emission laws that Europe has.
Regardless off the country of origin, the Police generally will only bother you if any vehicle of any type is exceptionally loud or you act like a dick. Even vehicle inspectors are not ott if you are decent.BMW makes no OZ market model so still same as OEM bike exhaust flaps come
Great. Count your blessings.Regardless off the country of origin, the Police generally will only bother you if any vehicle of any type is exceptionally loud or you act like a dick. Even vehicle inspectors are not ott if you are decent.
How does that improve the bike?
Reduced weight... Improvements are debatable.. the exhaust note sounds a little more throatier..How does that improve the bike?
Not being mechanically minded (ok, it’s a lack of ability), how is this different from just have the exhaust valve disconnected?
I had the opposite effect, was not as throaty/rumbly to me but more smooth when I disconnected the electrical connectors ... clicked them back soon after and prefer it that way.Reduced weight... Improvements are debatable.. the exhaust note sounds a little more throatier..
I don't think it improves the bike at all. Just a less subdued sound when rolling between 1,000 to 2,000 rpm.How does that improve the bike?
It is ONLY a ´Bobby dodger´ mechanism to meet EU sound emission tests; specifically the roll by and accelerate. Removing will increase the sound under those conditions. If not audibly, it registers on the dB meter.I don't think it improves the bike at all. Just a less subdued sound when rolling between 1,000 to 2,000 rpm.
By the same token, I don't think that the whole servo mechanism improves the bike in any way. So why have that.
You never had a NotSoModern (two stroke, hand shift) Vespa; Italian aircraft engineering.The exhaust servo unit is an example of over-engineering.
Generally speaking though, I like BMW engineering.
When I shift into 1st after starting the engine, I hear a faint click. When I shift into first on my HD StreetGlide, the bike lurches forward with a loud thud, as if I just sheared a pin.
Perhaps.Next the’s.
just disconnect plugs and use ESE BM1 x2anyone has any before/after videos of the exhaust servos disabled?
