My fishtail exhaust project
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1768230793#check"></use></svg></i> Discussion starter Discussion starter MilwDave
La estructura de malla es hueca por dentro y está envuelta con una manta de fibra de vidrio. No es diferente del embalaje típico del silenciador de motocicleta.
Si bien no estoy presente en el sitio donde se está realizando la fabricación, supongo que esos dos orificios son para igualar la presión dentro del silenciador. Dado que esencialmente lo estamos convirtiendo en un sistema directo, las colas de pez actuarán como un gran escudo térmico y nada más.
Los tubos de dirección están completos. Retiramos el catalizador y los conjuntos de aletas, los agujeros están soldados.
Cuando se complete el trabajo, todo el sistema estará recubierto de cerámica de color negro mate. View attachment 13302
Hey Dave, did you scuff sand before painting black? Is that flat black or matte black high heat paint? Did you use the same paint on the exhaust and cat pipes? I think it would look good on my slashed cut fish tail!
We polished down a few of the welds and scuffed the mufflers. The coating company will sandblast them before applying a high temp flat/satin black ceramic coating that is rated to 1800 degrees F.
If you’re wondering what the inside of your head pipes look like. You can see the flapper in its natural open position. It still takes up a fair percentage of the available flow volume inside the pipe. The catalyst is encased in a stainless steel mesh so it’s not as simple as hammering it out.
Stumbled onto this on YouTube. Has a video about modifying stock exhaust. They can do the work on your fishtails or sell you one’s done by them. No idea of cost and are located in Grimsby UK. A possible alternative for those of you who are not quite as talented as MilwDave. Search the realtoyshop on youtube.
Approximately $900 U.S. plus shipping and no one really know what they are doing for that price.
My guy will be willing to do the muffler modifications and you’ll only have to ship to Milwaukee.
