Reverse gear recall problem
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter Felix
Felix
china
r18
Hello, everyone,
BMW recalls the R18 with reverse gear function in China, It did not specify the reason for the recall
the current plan is to stop the function, BMW will provide improved reverse gear module in the future,
What are the solutions for other countries? Has anyone ever had a problem with reverse gear?
I have used the reverse gear only a dozen times or so in tight spaces..well worth the function! No problems and remember engine on, trans in neutral, kickstand up, clutch out.
Yes I use it daily, and it did have an issue at around 600 miles and 2 1/2 years of ownership, they replaced the control unit under warranty.
Hello, everyone,
I use mine without issue everytime I pull it out and back in my garage, up a slight incline
I use it every time I return from riding, without any issues; I had a little bit of a learning curve adjustment during the first week or two of ownership, everything was well documented within the owners manual.
Best tip - remove the stress weight of the bike before switching out of Reverse; rock the bike forward and grab the front brake, it should easily come out of Reverse via the lever.
Hello, everyone,
Yes had my module replaced at 7000 miles. So far so good
It’s easy to understand having a reverse on a 900 Lb bike.
I probably would not ask for a reverse on my R18, although 750 Lbs is a load.
Mine was replaced free of charge at 7000 miles.
What kind of issue? Yesterday I found that my bike is not working in reverse mode. The "R" is flashing. Tried once, twice, turning on and off the bike, then later at home but nothing...
Needs a new control unit. If you can get your hands on ISTA you can test it yourself.
Hello, everyone,
Never had any problems with it used it at least 500 times couldn't be without it 👍
