Luxury (no)problem :-)
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Petrus
Do you worry that the vibration will get to it or is it just for aesthetics when parked?
reflected on it and thought 'No´.
Went to take it off again and it is keeping perfect time. Also have become a bit accustomed to the look and it is actually functional to have time on the 'dash´ . Leaving it on for the moment. Will delete later :)
So, that leaves the fire extinguisher and the fake ignition switch/key for on top of the headlamp.
Have you considered a modern Marlin’s?
I’m very happy with the looks of my dual mount.
Would be interested in some pictures of this false ignition switch.
thanks for the suggestion.
Looks good.
I have this one in the wish list. Now I have seen them on your R18 it has risen to the top.
I highly recommend a genuine Marlin’s if you can. The quality is night and day from anything else. This is what I have:
You might prefer these for a more vintage look:
Of course, they also have solo clocks. There's a lot to choose from.
Here comes the Judge…. With a winning formula 🏆
I'm usually on the other end of being convinced I need a new part or piece of kit. Freddie Dobbs and other Youtube content is a common culprit. My wife calls these ‘bad influences.’ I suppose I'm a bad influence on r18forums.com now.
Thanks for the recommendation.
The one I have listed is 10€ shipped so I am tolerant with quality. Also like it being unbranded.
Ah and have taken the Molija off again.
Will share more photos of the faux ignition thingamies when I have them. It is the more compact one form the IFA/MZ which is also closed at the underside so easily fitted.
The black bit slides forward so potentially giving the option for the key too.
I have btw also found the original tyre pump:
Most of the parts for old BMWs are very easy to find over here and none too costly.
It helps if you know the correct name in German as it all comes from thataway.
fitted the vintage (fake) ignition lock. It looks the part 🤩 compared to the original R50:
Note the UK tax disc to the left of the head lamp. In Germany it was a sticker on the license plate. I have the Spanish thingamy.
