BT Moto ECU Flash Group Buy and Discount!
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1776214450#check"></use></svg></i> Discussion starter Discussion starter BT Moto
HD owners are insanely jealous. I kid you not --I go to a weekly meeting where a lot of HD motos park... without fail, and I'm talking every week, the R18 is the one everyone gathers around. Then I see a couple people break off and talk to the HD owers because they feel bad and give them consilatory compliments on their crappy little HD's. Even from a distance I see them still oogling the R18.
It's premium materials, precision build, epic style and aesthetics wipes the pavement with HD.
The R18 is what every HD wishes it could have been.:ROFLMAO::ROFLMAO::ROFLMAO:
Harleys are good bikes ... for what it is worth ... I still own a '66 Pan Shovel and wouldn't sell it if it is the last thing I do (profile pic) .... this said ... in a couple of weeks she will go into my living room .. simply because I don't ride the old girl anymore ... I am tired of kicking 1200 cc ... and I totally fell in love with the sheer comfort and feel good my Uschi (R18 FE 2021) gives me ;)
Harleys are (at this day in age) overpriced and live much on their reputation that was built way back with riders IMO ... but thats just me 😁
Inquiring mind wants to know how this panned out? Thanks
AS REQUESTED, THIS IS THE GROUP BUY POST
IF YOU'D LIKE TO SIGN UP, JUST REPLY TO THIS THREAD AND YOU'LL BE ADDED TO THE LIST
We will leave this active until February 14th (or until people stop signing up for a few days in a row)
COST:
Two tiers of cost
1. We get up to 10 people to purchase and we will give a $100 discount off our advertised $795 pricing
2. We get 20 or more people get a $200 discount off advertised pricing
WHO'S SIGNED UP SO FAR:
1. enzo5000
2. Adrian R
3. HanseDavion
4. Vyk
5. IDRider
6. azachko
7. burangs
8. estoma
9. Cheshire Cat
10. PistolPeteSTL
11. Lloydw1
12. R18BM3
13. MotoRey
14. Lepisale
15. Wreckit
16. Sancho
17. pbosik
18. BeerMe
19. TodkaVonic
20. B4rn3y
21. AlRBo72
22.
23.
24.
25.
Why Flash Your R18's ECU? (Info)
STAGE 1 BENEFITS​
Perfect fueling, all the time! The BMW R18 comes equipped with wideband oxygen sensors stock which fully target fuel at every throttle position. Once setup, the bike is running an “auto” tuner all the time! Never needing custom adjustments for aftermarket parts, etc. The bike will adjust itself for the new parts! With the options below we have a full on unleashed and aural riding experience to enjoy this motorcycle to it’s best possible potential.
Here’s a list of everything we did with Stage 1:
  • Full-Time Closed Loop (FTCL) Fueling Adjustments
  • Removed RPM “Soft” Limiter
  • Rough Idle Fix – Cold and Warm
  • Increased Torque Limits
  • Increased Throttle Limiter To 100%
  • Sharper Throttle Response
  • More Aggressive “Rock” Mode Rumble
  • Increased Ignition Timing
  • Fixed Bucking and Rev Hang
  • Removed Top Speed Limiter
HOW WE ACCOMPLISH THIS WITH STAGE 1​
RESTRICTIONS REMOVED. The OEM throttle model has “soft” and “hard” limits. The soft limits are where the R18 will start to close the throttle and limit torque by itself near the RPM limiter. We removed the soft limiter that comes in 600RPM before the factory RPM limiter.
MODIFIED FUELING FOR FULL-TIME CLOSED LOOP AND WILL TARGET FOR BEST FUELING AND PERFORMANCE. Full-time closed loop tuning means your R18 can be programmed to always target a perfect AFR (air/fuel ratio). This new technology was just introduced by BMW and we utilize it to work at all times for you with Stage 1. Want to change parts on your bike and worried it may change your fueling? Worry no more with Stage 1.
MODIFIED IGNITION FOR ENHANCED PERFORMANCE. Stage 1 optimizes the ignition tables for performance and reliability. The R18 has multiple ignition tables. Depending on fuel quality, the bike will either choose more aggressive or less aggressive ignition map.
IDLE AND STARTUP FIXES. Complaints of idle and startup issues are common. Stage 1 fixes these issues and ensures your bike starts up and idles right the first time, every time.
INCREASED TORQUE LIMITS. Torque limits removed to give you more torque in the midrange and low end (see dyno graphs below).
THROTTLE INCREASED TO 100%. Factory throttle limits are common these days. Our Stage 1 flash removes all throttle limiters and gives you the power your bike should have had right from the factory. The factory R18 throttle limiters are at 3500RPM.
SHARPER THROTTLE RESPONSE. Throttle response sharpened to give you a more lively and responsive feel on the road.
INCREASED “ROCK” MODE RUMBLE. Ready to Rock? “Rock” mode idle gives you slightly more rumble and shake, while “Roll” mode still retains its functions with no shake.
INCREASED IGNITION TIMING. Ignition timing carefully increased to yield optimized power while still giving you OEM reliability and rideability.
FIXED BUCKING AND REV HANG. Low RPM bucking and throttle lift “rev hang” have been reduced with Stage 1.
REMOVED TOP SPEED LIMITER. Top speed limiter of 110MPH had been removed with Stage 1
DYNO
The R18 isn’t know to be a powerhouse but there’s still power to be made. With our Stage 1 flash we were able to gain 6WHP and 4WTQ. We also were able to smooth the throttle with sharper response. All dyno runs performed back to back on our in-house DynoJet with the only difference being our Stage 1 flash.
BLUE = Stage 1 with 93 Pump Gas, 83WHP / 114WTQ
RED = Factory tuning with 93 Pump Gas, 77WHP / 110WTQ
The graph below shows partial throttle power. We gave the R18 more partial throttle power through the entire RPM range and were able to make the bike smoother and more predicable.
RIDE IMPRESSIONS
COST:
Two tiers of cost
1. enzo5000
2. Adrian R
3. HanseDavion
4. Vyk
5. IDRider
6. azachko
7. burangs
8. estoma
9. Cheshire Cat
10. PistolPeteSTL
11. Lloydw1
12. R18BM3
13. MotoRey
14. Lepisale
15. Wreckit
16. Sancho
17. pbosik
18. BeerMe
19. TodkaVonic
20. B4rn3y
21. AlRBo72
22.
23.
24.
25.
STAGE 1 BENEFITS​
DYNO
RIDE IMPRESSIONS
So any news is anyone got there tuner I want to get one but can't find any review or videos?
COST:
Two tiers of cost
1. enzo5000
2. Adrian R
3. HanseDavion
4. Vyk
5. IDRider
6. azachko
7. burangs
8. estoma
9. Cheshire Cat
10. PistolPeteSTL
11. Lloydw1
12. R18BM3
13. MotoRey
14. Lepisale
15. Wreckit
16. Sancho
17. pbosik
18. BeerMe
19. TodkaVonic
20. B4rn3y
21. AlRBo72
22. GARBOT (I already have a handheld so would only need to get the file modified, which I believe is $200)
23.
24.
25.
STAGE 1 BENEFITS​
DYNO
RIDE IMPRESSIONS
If you guys can get this to 10 units I'll do $100 off, if you can get it to 15 I'll do $200 off, following along for questions etc.
Thanks
Chris
A question (or 2) from me..... PM me if answer should be private..... if posting hand unit to downunder.... what would the customs declared value be..... I was thinking it might be for postage and hand held unit cost.... (as there is no tune file in it at that point).
Also, could the tune requested be for a r ninet rather then a R18?
Thanks all! Appreciate the info and perspectives! Definitely something to consider and frankly speaking I get the same impression that it is NOT a night and day difference hence I'd get it if I can get it for that $595 mark.
We can create a list on this thread response and keep editing it with new names as more people show interest until we hit 20+ on the list (since some may change their minds etc.). I can volunteer for this - reply or DM if interested and I will keep editing the list below.
1. @NAK58D
2. @physiqo
3. @Witsend
4. @iamtheJwalker
5. @2litsTranscontinental
6. @Caio HH
7. @Ninja
8. @Hegy
9. @Browny
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
9 out of 15 (preferred goal). We got this come spring time!! 😁
Add me ..... they are ok with a r ninet tune... it's the same price.... my only condition is making 15.....
Hey guys - I am new to the forum and thanks to @Noelpolar also coming over from the ninetowners forum.
Interested in the BrenTune myself and was curious to hear more about the group buy.
1) Whats the cut-off date? Saw Feb 14 above but not sure if that was from a previous group buy
2) Whats the actual price if we get to 15 buyers? $200 off $895 or $795? Looks like $895 is the current price but saw @NAK58D mention the $595 price.
Thanks a lot for organizing the group buy!!
Cheers!
